Hi, is it possible to fix an upload throttling issue I'm having with DO 12 Pro? If I use Windows File Explorer to upload the same files I can get upwards of 10Mbs speed increase. I Have a Beyonwiz PVR with Gigabit Ethernet to which I send downloaded YouTube files etc, I use a WiFi extender to connect the computer to the PVR and I find using File Explorer to be much faster, why is that and can it be fixed? I'm not a programmer and I will need to have any technical solution sounded out if that's OK? Thank You
Using Filezilla seems to be very fast, so that will be my goto for now, bookmarking makes it less cumbersome. Any idea when the speed upgrade will come to DO? Thanks
No, my PVR is on my home WiFi router net. I need OP12 to be faster, but in the meantime I'm going to use Filezilla (which appears to be faster, maybe?) because it has the dual pane view that's not available with File Explorer without faffing around with two instances. DO12 is brilliant for that, which is why I bought it. but it's way too slow. Sorry for the confusion.
