DO 9.1.1.0: Glass-Statusbar not working
Activated Glass-Statusbar (Vista) doesn't work.
Could you post a screenshot of the lister window and the Preferences window as well please?
Did you see a glass status bar before 9.1.1.0?
Is glass enabled on your desktop (e.g. for titlebars)?
Here's a screenshot. Appears on two pc, both Vista, both glass activated (as you can see on screenshot).
You may see that I use a background-image, deactivating image/systemcolor also doesn't change to glass look.
Edit: I used glass look in first/second version of DO 9 and it worked, but I don't know if this appears only since latest DO 9.1.1.0.
The window's maximized by the look of it. From the release notes:
Ah, overseen!
would it be possible to have it as an option to have aero glass on maximized? i think i kinda like it that way more...
