DO11: 3-buttons state when alt or ctrl pressed
I try to understand why when I press alt or ctrl keys and no files selected, my 3-buttons is activate.
<?xml version="1.0"?> <button display="both" separate="yes" type="three_button"> <label>Casse</label> <icon1>#rename2</icon1> <button display="both"> <label>1ère lettre</label> <tip>1ère lettre en majuscule et extension en minuscule</tip> <icon1>#rename2</icon1> <function type="normal"> <instruction>@nodeselect </instruction> <instruction>Rename CASE=allwords</instruction> <instruction>Rename CASE=extlower</instruction> </function> </button> <button display="both"> <label>Majuscule</label> <tip>Majuscule (maj pour extension)</tip> <icon1>#rename2</icon1> <function type="normal"> <instruction>@keydown:none</instruction> <instruction>@nodeselect </instruction> <instruction>Rename CASE=upper</instruction> <instruction>Rename CASE=extlower</instruction> <instruction>@keydown:shift</instruction> <instruction>@nodeselect </instruction> <instruction>Rename CASE=extupper</instruction> </function> </button> <button display="both"> <label>Minuscule</label> <tip>Minuscule (maj pour extension)</tip> <icon1>#rename2</icon1> <function type="normal"> <instruction>@keydown:none</instruction> <instruction>@nodeselect </instruction> <instruction>Rename CASE=lower</instruction> <instruction>@keydown:shift</instruction> <instruction>@nodeselect </instruction> <instruction>Rename CASE=extlower</instruction> </function> </button> </button>
Thanks, this will be fixed in the next update.
I always have the same problem with this 2 buttons but only with alt key.
Rogner.dcf (6.54 KB)
Insérer.dcf (7.09 KB)
Sorry again but now, I have problem with this button when I press ctrl key and no file selected...
<?xml version="1.0"?> <button display="both" separate="yes" type="three_button"> <label>&amp;Déplacer</label> <icon1>#syncpane1</icon1> <button display="both"> <label>Par date</label> <tip>Déplacer dans des dossiers par date (aaaa-mm) (shift pour aaaa-mm-jj)</tip> <icon1>#syncpane1</icon1> <function type="normal"> <instruction>@keydown:none</instruction> <instruction>@disablenosel </instruction> <instruction>@nodeselect </instruction> <instruction>Rename REGEXP PATTERN (.*) TO {modifieddate|D#yyyy-MM}\\\0 FILEINFO</instruction> <instruction>@keydown:shift</instruction> <instruction>@disablenosel </instruction> <instruction>@nodeselect </instruction> <instruction>Rename REGEXP PATTERN (.*) TO {modifieddate}\\\0 FILEINFO</instruction> </function> </button> <button display="both"> <label>Par extension</label> <tip>Déplacer dans des dossiers par extension (maj par nom de fichier)</tip> <icon1>#syncpane1</icon1> <function type="normal"> <instruction>@keydown:none</instruction> <instruction>@disablenosel </instruction> <instruction>Copy MOVE HERE CREATEFOLDER {o|ext2}</instruction> <instruction>@keydown:shift</instruction> <instruction>@disablenosel </instruction> <instruction>Copy MOVE HERE CREATEFOLDER {file|noext}</instruction> </function> </button> </button>
