Please try this:
Open Advanced Selection dialog, select Date, select Modified/Within/Week, I see Modified/Within/Week combo box don't show item list, but I can select items with the arrow keys on the keyboard. The same combo box issue happens to Date/Time, Document, Image, Music, Path length, Rating, Script Column, Size, Time, Type. This is the screenshot:
Confirmed, although it only happens on Windows XP and can be worked around using the cursor keys to change options.
Microsoft no longer support or update XP and the OS is no longer safe to connect to the internet. Modern development and debugging tools no longer run at all on XP, severely limiting our ability to work with it.
At the same time, we understand that some people are stuck having to use XP. With Opus 12, we aim to fix serious bugs which stop the program from working at all on XP, but may take longer with less serious issues.
There are also parts of the Opus 12 UI which will work worse on XP because they've been redesigned to use features only available in modern versions of Windows. (One example is the Folder Formats: Columns tab, where XP gets a long, flat list of columns because XP does not properly support the grouped listview control we use on Windows Vista, Windows 7, Windows 8, Windows 8.1 and Windows 10.)
So we may fix this but we strongly urge you to move to a version of Windows which Microsoft & modern dev tools support, made more recently than 14 years ago.
