DO12 - Does not remember folder options
Under context menu - View - Folder Options, we have a nice set of options to make our folders show, just as we like to see our folders.
Unfortunately, the selected and saved folder options do not stick.
At next launch of DO12, usually after a shut down, All my options are gone. I have to make the same selection again every time I launch DO12.
Which of the save options did you use?
How are you opening the new windows after launch?
After you mentioned the way I am saving the folder option, I used the "Save" button and now I can close DO12, Relaunch and see the folder options stick.
Thank you.
