A lot of times when I hover mouse over a folder it fails to calculate the size and show the partial content within the tooltip. It will show for example...
instead of
This happens when I've just navigated to a folder, and hover over a folder for the first time. Once this happens if I hover over a different folder it usually calculates normally. And once one folder calculates all others will too. Again, it only seems to happen on the first hover of a entered folder, and will continue to happen (on the same folder) until I hover a different folder. Then this behavior can all happen again once I navigate to another folder. This doesn't happen 100% of the time but around 70%. Hope my explanation isn't confusing.
Here is what I have set in my "Info Tip" tab under "All Folders" within File Types dialog.
<b>{foldersize}</b> {dircount}/{filecount} <#808080>{dircounttotal}/{filecounttotal} ({pathlen})</#>
{foldercontents}
I'm sure this began in 12.0.8
Thanks
