DO12 - Issue changing iconsets
When changing iconsets (add/remove/on top) the icons in menus are cropped. Need to exit and restart DO to fix.
Can you give us a quick step-by-step list on how to reproduce this?
e.g. "Download and install Icon Sets X and Y, then move X above Y" or similar?
It happened when loading an iconset (DO11), set it to top and apply. But I also noticed that DO shows 40x40 instead 32x32 for large, so it seems that it's caused by iconsets not including an updated xml.
It happened 4-5 times, but I can't reproduce it.
Icon sets are now assumed to be 96DPI unless they specify otherwise, so if you have Windows set to a higher DPI it could cause a 32x32 set to be enlarged to 40x40. That part is normal.
If you can work out a way to trigger the cropped icons, or stumble on it again, please let us know. I think I saw something similar once, so I believe you, but I haven't been able to reproduce it since myself, and until now thought it was due to messing around with DPI debug settings that aren't exposed in the normal builds.
Ok, I'll have a look.
Ok, just tell what I did today (I don't know, what exactly triggers the issue!). Using DO Beta 4!
I once changed scaling from 125% to 100% without restarting. Hours later added another iconset and it is shown as you can see in picture below (the icons are scaled up and are not 32x32). As far I can say it's definteley only happen when adding iconsets using the older format.
Updated all iconsets (new dpi-entries) and the issue is gone when switching between the sets.
