DO12 - Minor suggestion, rating stars, manual
This new function is great. Maybe the manual should mention, that clicking the "one star" icon is designed to reset the rating to zero. I tried dragging it towards the left side, which resulted in some "drag & drop".
I assumed, that clicking left from the first star would trigger the reset, but that seems not to be the case. Maybe some "info tip" on the left star could indicate, that we can reset the rating by clicking there.
It should already preview what will happen as you move the mouse over the stars.
At the far left there are no stars filled in, and as you move the mouse towards the right it will go from 1 star (in the right half of the 1st star) through to 5 (over the 5th star). If you move the mouse away from the stars they revert to the current rating (if any).
[quote="leo"]It should already preview what will happen as you move the mouse over the stars.
At the far left there are no stars filled in, and as you move the mouse towards the right it will go from 1 star (in the right half of the 1st star) through to 5 (over the 5th star). If you move the mouse away from the stars they revert to the current rating (if any).[/quote]
Ok, i think now i got it. First i tried dragging it like a slider, which didn't work quite well. If i have the size set to "auto", it's also very tight. But with the size of "100" it's indeed quite easy to reset the rating.
