My default mode is power mode. I often hold down the left button to drag files or select files or folders, but often enter the state of renaming files. How can I turn it off?
Thanks
Thanks
PowerMode doesn't rename files that way by default.
What have you set your left mouse button to do in Preferences / File Display Modes / Power Mode Buttons?
Auto-deselect
I remember there seems to be a parameter to turn it off.
I found two, single_click_rename
, slow_dblclk_rename
. Whether they are true or false, it doesn't work for holding down the left button.
Thanks.
I don't think you can turn it off when using Auto-Deselect at the moment, but we will add something in 12.18.1 (not 12.18) to let you do that.
Thanks Leo, I am looking forward to it.
