Hi,
I'm getting a crash when I use an encrypted USB stick supplied by my workplace. It uses something called Integral TotalLock to encrypt the stick. The same stick used to work with DOpus 10 OK.
I've attached a picture of the crash dialog which has an address that may mean something to you.
It isn't stopping me work, DOpus restarts OK and the USB stick works after the restart, just thought you should know.
Steve.
