Latest iteration. Considering going back to flat colored icons...
This is Great,,, I want mine to look like this ![]()
Is there a Template for this them, I really like it ![]()
Appreciate the kind words. I have not used this setup in years and do not have a template. Note DO13 is much more customizable than DO12, for which this setup was last used.
That said, some options (assuming familiarity with DOpus basics such as layouts AND willingness to tinker):
- If it's the colors you're after, use a color picker to identify them.
- This phenomenal tutorial thread will walk you through customizing a theme to suit your needs: How to create a custom theme in Dopus 13
- Review Icons - Directory Opus Resource Centre for other optional icon sets, if interested
- Consider adding your own icons to suit and/or cover specific commands/programs
Yes, Ive used Opus for a number of years now, mostly just file management never really personalised my setup.
I'll Tinker a bit and give it a go.
The Colours and also the way you seem to have all your tabs across the top and sides into like Icon groups that take up little space
THanks for the reply and links ![]()
Great colors ! Love steeb blue...
