I have a small problem since Dopus 9 with the Image Resize Feature.
Specially when I Resize an image (e.g 100 x 50) and just set the Height of the Image (25) and leave the Width empty then Dopus resize it to 25 x 12 (preserve aspect ratio ON), correct it would be 50x25.
So it looks like DOpus use the Percentual resizing when you leave the width empty. when you use the height empty and set the width with Aspect ratio ON then it resize it correctly ...
[quote="X-Tender"]Yes, but i doesnt want get a 100x25 image. . i want a 50x25 ...
because i have many images and what to change the height to one value but keep the aspect ratio of the image ..
for now i solve it with the script ..[/quote]
Sorry, I typed the wrong thing.
If the input image is 100x50 and you tell Opus to resize it to 9999x25 + preserve aspect ratio, then the result will be a 50x25 image. (Since Opus will shrink it to fit within a 9999x25 rectangle.)
