DOpus and dbPowerAMP?
Hi there,
i lately installed dbPowerAMP Music Converter. During install you have the option to select, whether file-info pop up should be shown or not. If checking that option, it works fine in Explorer, but not in DOpus.
So is there a way to 'bypass' DOpus info popups and replace them with that of the wanted application?
Regards,
Ralph
1 Go to Settings/File types
2 File Type Groups and double clic on "Music"
3 Tab Info Tip and replace all InfoTip definition by {infotip}
Out of interest - what does dbPowerAmp show in the tooltips that Opus can't/doesn't?
[quote]
tanis wrote:
Out of interest - what does dbPowerAmp show in the tooltips that Opus can't/doesn't?[/quote]
To be honest, nothing of interest or nothing DOpus could show as well except compression ratio...
Regards,
Ralph
