DOpus BETA 7 Show Empty Drives setting not working
My DVD drive is letter E: I have the "Show empty disk drives" box checked (enabled) as seen here:
However, the DVD drive is not listed in the Lister. Is there a setting elsewhere that over-rides the "Show empty disk drives" setting? Windows Explorer shows the DVD drive, by the way...
The page you're looking at there affects the Computer folder in the file display.
There are separate options for the folder tree: Preferences / Folder Tree / Contents.
Thank you, Leo. Once again you are the man.
