DOpus crashes and exits when searching for contents . Failing module: OFFFILTX.DLL
Hi,
Running DOpus 13.11 x64 on an ARM64 MS Surface Pro 11.
When DOpus searches for files containing some strings it crashes and exits.
Event viewer reports OFFFILTX.DLL as the failing module.
DOpus does not generate any crash log.
I (think I) understand OFFFILTX.DLL is used to "read" the content of MS Office files.
As MS Office files are essential for my work this is vers annoying.
There is no problem on my x64 computer when searching through the same files.
Any thoughts?
OFFFILTX.DLL is part of Microsoft Office, not our code.
It's probably an IFilter, which will be called to search inside Office documents, whether it's Opus, File Explorer, or something else doing the search.
We can tell you how to disable the IFilter, but that may result in not being able to search inside those documents. Fixing the DLL requires Microsoft's support rather than ours (assuming your version of Office is up to date etc.).
Thank you for the reply.
Yes my installation is up to date.
Unfortunately Office files are 99% of the files I usually search inside.
Well, I just have to wait and hope :wink: and use the native File Explorer for searching in the mean time.
If OFFFILTX.DLL is crashing for some documents, it will probably also crash when File Explorer uses it to search them. (Or possibly crash the Windows indexing service when it scans the files, if Explorer is using a cached index for the things being searched.)
Explorer obviously uses a cashed index because the results are almost instantaneous.
It correctly finds MS Office files according to their contents. I understand it means those files have been scanned without crashing the index service.
Maybe only some very specific files make the service crash and the other ones are scanned correctly. Difficult to know.
You can use the same index in Opus via the search field’s Windows Search mode, if that helps.
Sorry or the late reaction.
Yes, your comment was very helpful.
Thank you
