Dopus.exe error message - Entry point not found
On startup, I get the message "The procedure entry point stricmpnWF could not be located in the dynamic link library dopuslib.dll. This has continued with the latest release 10.0.5.0. I press OK and everything seems to work properly. Any suggestions?
Try installing Opus again over the top of itself, and make sure you reboot at the end.
