I just noticed that I have a desktop icon with a hint that says Direct Access to DirectoryOpus Favorites. I don't know how it got there and would like to delete it, but can't find anything in the preferences that would allow me to do so. Any help would be appreciated.
You must have installed this at some stage. It seems to use a proper install system so there should be an entry in Add & Remove Programs to remove it.
You are absolutely correct. I don't know when I installed it. I removed it, and then had to delete it from the desktop. Thanks
