Hey,
I am using DOpus 11.5.3 x64 on a Windows 7 virtual machine (same problem with 11.5).
When I navigate through folders, sometimes DOpus hangs for seconds
When I try to delete files, sometimes DOPus hangs for seconds
This does not happen in Windows Explorer.
This does not happen with v 11.4 on a XP virtual machine.
Any ideas what can cause this issues?
Thanks in advance
Dinkelhopper
Jon
July 30, 2014, 7:45am
2
Try 11.5.3 on the XP virtual machine and if it doesn't have the same problem you'll know it's something to do with the Windows 7 VM rather than the specific version of Opus.
Everything works fine on XP with 11.5.3
Any ideas for the virtual machine?
Jon
July 30, 2014, 12:59pm
4
What other software do you have installed on it?
Ok, it's McAfee... It seems to work different on Win7 then on XP...
Thanks otherwise.
