DOpus internal viewer lock when using some small PNG files
Hi,
I have found PNG files that make the DOpus internal viewer lock (ie: the viewer window isn't refreshed anymore, and DOpus CPU usage stays at near 100%).
Please note that the files are displayed correctly in the lister (ie: when the lister is in thumbnails mode). The problem only appears when viewer the files in a separate window using the internal viewer...
This happens with DOpus 9.0.2: I haven't updated to the latest version yet, and I don't know if it happens with previous versions.
See post attachement.
Btw: I didn't know if I should use the support form on the dopus site for this type of report, so I first posted it... If I need to post it on the dopus site, just let me know...
Thanks for the report, however this was fixed in 9.0.0.4.
