I'm having a problem, that I find very peculiar since I've never experienced the issue in the years I've used DOpus.
At some point, it seemed to have lost the ability to remember my lister setup and open tabs after closing and reopening it, instead reverting to the open tabs from several weeks earlier.
Here are the steps I took to try to fix the issue myself:
I made sure that the option "Open the listers that were open when the program was last closed" was checked. (It was)
I backed up my configuration, went to /dopusdata and deleted everything in the folder, then restarted DOpus. However, this ended up deleting all toolbars and menus, so I followed the instructions given here Missing toolbar menu to try to bring them back, only to find out the list of available toolbars was blank.
I completely uninstalled and reinstalled DOpus (downgrading from the 12.17.4 beta to the 12.17 stable), re-inputted my license code, and restored my configuration from the backup I had made earlier. This made my setup just as it was, except that both the left and right sides of the lister only had tabs for C:\ and my custom toolbars weren't visble. I brought them back up, arranged them as I wanted, and brought manually back up my tabs. I thought everything was fine at this point, until I went to close DOpus and reopened it. At this point, DOpus just loaded it in the state it was in right after I restored my configuration from the backup.
So with things as they are, I can't close DOpus unless I want to lose all the tabs I have open and rearrange my toolbars each and every time.
Is there a way to fix this problem? I thank you in advance for the help.
