Hello,
dopus is not showing magic disc virtual drives, can you help me ? Drives ok in explorer, not in dopus
Thanks
Hello,
Thanks
Not showing them where? The toolbar? Tree? My Computer folder?
Do they show up if you fully exit Opus and then restart it?
I got it, they only show up if there's something loaded into the drive, if it's empty they don't show
There are options to change that if you want.
