Greetings All
Does this exist?
I make extensive us of the DOpus.Output method in all my simple little scripts.
I have reason to want to do the same for some Internal Command based buttons.
Thanks...
How can I see what my opus scripts resolve to? - #4 by Leo discusses a few ways to show output from non-script buttons, including a simple script add-in which adds a command to output text to the log which you can use in them.
Command: Say (print text to the script console) has a similar but more advanced script add-in.
