Dopus reset to root folders after ejecting a CD
It already does, doesn't it? I've always had autorun turned off but the tree updates here when a CD is inserted or removed.
Autorun might be needed to reproduce the problem that this thread covers but it shouldn't be required just for the tree to update, as far as I know.
Autorun might be needed to reproduce the problem that this thread covers but it shouldn't be required just for the tree to update, as far as I know.[/quote]
Nope, the drive section of my tree never updates until I manually refresh the My Computer display. Now that I think about it, I'm probably missing some auto-refresh setting for My Computer. I didn't see anything in the Opus options though.
[quote="artema"](Edit 2008: This issue should be fixed now. Just happened to be passing through the thread. --Nudel)
Hi!
Well, that's it! Having a dual dopus lister when I eject a cd from my IOMEGA CD/DVD drive both listers browse to its root folder automatically.
I guess that's the normal way if lister was formerly browsing the cd/dvd contents, but not when it's listing anything else.[/quote]
I'm still having the described problem with DOpus 9.1.0.3 (XP Pro, All Updates)
Does anyone have any solution?????
What should be done?? Enable/Disable Autoplay???
Please help me!
I also have this problem (9.1.1.3 ... yeah, I know, I've been busy). Whenever a CD is ejected, the Source lister jumps to the system root unless DOpus is the active window at the precise moment that the CD ejects. In my case, this usually manifests while I'm ripping a CD. The CD ripper ejects the CD when it is finished. Unless I was working in DOpus at the precise time th at the CD ejected, DOpus jumps to the root.
This is happening to me too under 9.1.1.7 on XP32.
I am copying a bunch of DVD contents to my HD (a sample library, 35 DVDs worth!). In my top lister I have the DVD inside a couple of folders, and the bottom lister is a folder on one of my HDs. After copying, I eject the DVD, and both the top and bottom lister reset to showing My Computer.
ARRGH
There was a change affecting this in 9.1.1.8, released three months ago. Try using the latest version and see if it helps. If not let us know.
Thanks Leo; I updated to 9.1.2.0 and indeed it seems to be behaving it's self now.
