DOpus Viewer does not handle color space / color profile correctly
Hallo,
I am using DOpus since a few days, and I love it! Make the File Explorer looks like a dinosaur, and reminds me the old days in Amiga )
However, I found an issue for my work flow. I am working with pictures and videos on calibrated monitors. It means each monitor got its own color profile to match reality.
However, the viewer from DOpus seems to ignore totally that. InfraView requires a plugin to handle that correctly.
Would it be possible to add that in DOpus ?
To notice the difference, look at the same pictures in the Windows Photo program and DOpus's Viewer on a calibrated (color profile enabled) monitor.
Thanks!
Regards
There's very limited support for color profiles in the viewer. See use_color_management under Advanced [Directory Opus Manual]
Thanks. I could not notice much difference playing with the different settings. Also, I have 3 monitors... so the profile should be correct on each of them.
I guess this is much work... but otherwise the colours just looks off.
Any chance to get it better in the future release ?
