hi been using Opus since early days of the amiga would not be without it,
my issue is under win10 64 would like to keep groove music as default music player
but when I double click mp3 file in opus nothing happens if I use open with command it plays in groove just want to know if the is way to fix it to always play in groove
Cheers
Nick
Have you tried using Open With and telling it to change the default app?
yeah tried that no joy
Try going to Settings > File Types, then assigning FileType ACTION=open
to the left double-click event.
Example of what it should look like (of course, edit the type with the problem; TIF is just the example the screenshot uses):
