hello,
i can't find how to change the option of copy/paste to cut/paste and the opposite when i do drag and drop between the tabs in d.o. 10.
thanks
Filetypes > All files and folders > Drag n drop options
ok and when i click to drag and drop i see the command: copy movewhensame , what do i have to write to replace the copy command with cut?
I'm not quite sure what you're asking, but if you want drag & drop to always move files, change the command to copy move.
If you want drag & drop to always copy files, change the command to copy.
Movewhensame means if file/dir is on the same partition it will be moved, otherwise it will be copied.
thanks for the answer, but what should i change int he case where the file isn't in the same partition and tab?
anyway i did it, as the friend above suggest me to change the command to copy move for cut option, thanks
[quote="jon"]I'm not quite sure what you're asking, but if you want drag & drop to always move files, change the command to copy move.
If you want drag & drop to always copy files, change the command to copy.[/quote]
thanks
