when I dropping a icons from Directory Opus to desktop it does not locate where I drop the icon unless wait a minute or refresh desktop icons.
I put a video that compares file explorer and directory opus.
The Desktop is part of Windows. Opus plays no part in what it displays.
@hamed did you ever figure this out? I'm having the same issue. It only happens with Directory Opus as well. I narrowed down the issue, it only happens when DO is launched after explorer.exe.
After 2 hours of troubleshooting I managed to bandaid fix it by forcing an explorer.exe restart the first time DO is started. It significantly increased the time required for my PC to be usable after a boot, and it sucks that this needs to be done, but it works. But it's all I can do since DO devs likely won't fix this.
Not sure if it's broken like this for all DO users or just on specific setups. It's probably something going awry during shell hook. DO doesn't send change notifications if it's launched after explorer.exe.
