Drag & Drop does not work with Dopus 9.1.1.6 and WinRAR 3.80
Hi,
i just bought Dopus 9 and i'm really happy with this software, but it seems to have problems with WinRAR 3.80
I installed the trail Version, and each time i try to drag frile from the winrar window onto a Lister, winrar extracts the file but does not copy/move it to the location i selected.
I've read a posting in this Forum describing the Problem with Unicode filenames, but the files i like to extract hame simple ascii file names.
Can anyone confirm this, or is this just a malfunction/configuration of my system?
Best Regards
Kornelis
If you downloaded 9.1.1.6 before 20th December than please download it again from GPSoftware.
A problem was found with drops from WinRAR and Firefox and was solved in a silent update on 20th Dec.
That was the solution.
Thanks a lot.
Kornelis
