I have a Drives toolbar, but it's not showing buttons for drives that are mapped to folders (via Win-7/Explorer).
I have the
Go DRIVEBUTTONS /hideempty
line in the command...but the mapped drives aren't empty.
Is there a way to make these show up?
Regards,
Chuck Billow
Steve
2
The command should be Go DRIVEBUTTONS=hideempty. Not sure if that will help with the problem though.
Steve, I'll give it a shot.
Thanks,
Chuck
Steve, no, the command works, but it doesn't show those mapped drives.
Thanks anyway...
Chuck
tonym
5
It works for me, so it must be something other than the command. I'm using 9.5.1.0.3624.x86 on Window 7.
Leo
6
Do those drives appear in the folder tree? What about in My Computer?
Leo:
I found a problem with my (Windows 7) install, and once that was fixed, so were my drive buttons.
Thanks,
Chuck
