Drive icons
How can i change drivebutton icons (disc C, D...)?
The easiest way is probably to create an autorun.ini file as described here:
resource.dopus.com/viewtopic.php ... rive+icons
(abelthorne's 2nd post in the thread, 10 Aug 2005 10:43, currently the last post.)
Or in my opinion it would be easier instead of using the drive buttons, just make a shortcut to your drives and then you can change icon picture. See images below.. AS you can see now you can edit them.. Good luck
