Dropbox smart sync & previewing files in viewer pane
Hi, I have all of my files stored on dropbox and I use the smart sync feature. My default approach is to keep everything stored online and not locally. Up until about a month ago when I moved to a new laptop, I was able to select a non local dropbox file, the file would be downloaded and it would appear in the viewer pane. Ever since I've moved to my new laptop, selecting a non local dropbox file will cause the viewer pane to freeze and a file preview never appears. The folder tree columns still operate normally during this time.
Any ideas on how to solve this issue?
Thanks.
Which version of Opus are you using?
Hi Leo,
Directory Opus Pro 12.9 Build 6724 x64
OS 10.0 (B:17134 P:2 T:1) SP 0.0
Thanks.
That version should support Dropbox Smart Sync.
I would look at firewall and antivirus software/configuration as a potential difference between the two machines, if it was working on the old one but no longer does on the new one.
The only software difference is that the new machine has bit locker enabled. Is that a possible issue?
That should not affect things as far as I know, assuming the drive is either unlocked when you're doing things with Dropbox, or not involved with the Dropbox storage at all.
I did some testing and turned off bitlocker. No change in behavior.
I then did some further testing with onedrive and their version of smart sync. File previews in the viewer pane worked perfectly. I had always had plans to migrate from dropbox to onedrive, so this speeds up the timeline and solves the issue for me.
With no need for dropbox, I suppose it really doesn't matter to me anymore if the viewer pane works with dropbox or not. You can consider this issue resolved.
Thanks.
