Hi guys,
When viewing several folders in flat view, all of which contain the same filenames, can I hide the duplicate files?
With Duplicate Files
Without Duplicate Files
Regards
Blueroly
Hi guys,
Regards
Blueroly
Not in general, other than by hiding them individually (or hiding everything in the folders they are in, but that would not only hide files with the same names).
Filtering on a script column might let you do it for a particular starting point, where the script checked all the folders for others of the same name.
Often with flat view two files with the same names will have different contents (e.g. folder.jpg is a common example).
