Duration & dimension columns not showing for certain MP4 files
Video metadata of duration & dimensions does NOT show up for 1920 x 1280 --
it show for everything below that resolution.
I have had Icaros latest version installed for years, but for some reason I'm just now noticing
how that metadata is missing for the higher-res videos.
I use installed MPC-HC 64-bit the most recent available from the [abandoned] website,
so it uses self-contained codecs, right?
I've searched and found what seems to be an excellent scripted solution here,
but I wanted to ask my question 1st before getting involved with the script,
so is there anything else I could/should check, or just install this script? Thanks! --
Which format of video?
(Edit: I've added MP4 to the thread title to help people with the same issue find it.)
sorry -- .mp4 currently
(though I eventually convert all to .mkv for the chapter-ing functionality)
No issues with 1920x1080 mp4 files here.
I don't know if I have any 1920x1280 ones to test with, but the dimensions shouldn't matter.
Something else about the videos may be confusing things, though. Is there a small sample video we can try with somewhere?
Does it matter that it's actually .webm format?
edit - checking quickly, I do have webm enabled in Icaros -
dOpus v12.20 Win 7 x64
Here's MediaInfo's description of a 13.8 mb file:
Format : WebM
Format version : Version 2
File size : 13.9 MiB
Duration : 2 min 26 s
Overall bit rate mode : Variable
Overall bit rate : 794 kb/s
Writing application : Lavf57.71.100
Writing library : Lavf57.71.100
FileExtension_Invalid : webm
Video
Format : VP8
Codec ID : V_VP8
Bit rate : 562 kb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 30.000 FPS
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.009
Stream size : 9.81 MiB (71%)
Language : English
Default : Yes
Forced : No
So they're .webm files, not .mp4 files as you said previously?
Yes that would matter.
dOpus lists it as .mp4 in the file extension --
this is governed by Windows, right?
In any case, a quick experiment I just did --
using Handbrake, converted the file to .mkv maintaining same native resolution,
and now YES both duration and Dimensions show up!
Edit -- just noticed that line under MediaInfo --
If the extension is .mp4, it's either an MP4 file or it has been misnamed with the wrong file extension.
webm and mp4 are different formats.
Well there we go -- I made a copy of the "x.mp4", then renamed the extension "x.webm" ,
and it instantly shows both duration & time :joy:
So thanks for helping me learn something here today -
increased the problem-solving skills a little bit more :+1:
yes Thx - this will help another temp. lost soul like me understand it -->
from your query at the bottom of the thread
