DurationAV (Duration columns for folders)
This add-in creates six custom columns: DurationAV, DurationAudio, DurationVideo, DurationAVAvg, DurationAudioAvg, and DurationVideoAvg.
Like the built-in duration column, these columns display the lengths of audio and video files. However, unlike the built-in column, they also work for folders, showing the sum of durations for all files within each folder (non-recursively).
The DurationAV column represents the combined total of DurationAudio and DurationVideo.
DurationAVAvg, DurationAudioAvg, and DurationVideoAvg display the average duration per valid file.
How to set up and use
:one: Save ColumnDurationAV.js.txt to   ↓
:two: Toggle the columns with
Set COLUMNSTOGGLE="duration(!,a,0)"
Set COLUMNSTOGGLE="scp:DurationAV/DurationAV(!,a,0)"
Set COLUMNSTOGGLE="scp:DurationAV/DurationAVAvg(!,a,0)"
Set COLUMNSTOGGLE="scp:DurationAV/DurationAudio(!,a,0)"
Set COLUMNSTOGGLE="scp:DurationAV/DurationAudioAvg(!,a,0)"
Set COLUMNSTOGGLE="scp:DurationAV/DurationVideo(!,a,0)"
Set COLUMNSTOGGLE="scp:DurationAV/DurationVideoAvg(!,a,0)"
Things you might enjoy reading
The script's inner workings
JScript
function OnInit(initData) {
    initData.name = 'DurationAV';
    initData.version = '2024-11-14';
    initData.url = 'https://resource.dopus.com/t/durationav-duration-columns-for-folders/42701';
    initData.desc = 'Display duration for folders.';
    initData.min_version = '13.0';
function OnAddColumns(addColData) {
    var col = addColData.AddColumn();
    col.name = 'DurationAV';
    col.method = 'OnColumn';
    col.justify = 'right';
    col.type = 'duration';
    col.multicol = true;
    col.name = 'DurationAudio';
    col.name = 'DurationVideo';
    col.name = 'DurationAVAvg';
    col.name = 'DurationAudioAvg';
    col.name = 'DurationVideoAvg';
function OnColumn(scriptColData) {
    var item = scriptColData.item;
    var durationAudio = 0;
    var durationVideo = 0;
    var countAudio = 0;
    var countVideo = 0;
    if (item.is_dir) {
        var folderEnum = DOpus.FSUtil().ReadDir(item);
        while (!folderEnum.complete) {
            var folderItem = folderEnum.Next();
            var meta = folderItem.metadata;
            if (meta == 'audio') {
                var d = meta.audio.duration;
                if (typeof d == 'number') {
                    durationAudio += d;
                    countAudio++;
            } else if (meta == 'video') {
                var d = meta.video.duration;
                    durationVideo += d;
                    countVideo++;
        folderEnum.Close();
    } else {
        var meta = item.metadata;
            durationAudio = meta.audio.duration;
            if (typeof durationAudio != 'number') durationAudio = 0;
            countAudio = 1;
            durationVideo = meta.video.duration;
            if (typeof durationVideo != 'number') durationVideo = 0;
            countVideo = 1;
    scriptColData.columns('DurationAudio').value = durationAudio;
    scriptColData.columns('DurationVideo').value = durationVideo;
    scriptColData.columns('DurationAV').value = durationAudio + durationVideo;
    scriptColData.columns('DurationAudioAvg').value = countAudio ? durationAudio / countAudio : '---';
    scriptColData.columns('DurationVideoAvg').value = countVideo ? durationVideo / countVideo : '---';
    scriptColData.columns('DurationAVAvg').value = (countAudio + countVideo) ? (durationAudio + durationVideo) / (countAudio + countVideo) : '---';
Update 2024-11-14
  • columns now have Opus 13 duration type
  • added columns that show the average duration
