TL;DR
A script that can set the folderformat for subfolders of a specified folder but not for the folder itself ("everything below x should have this format"); before or after navigation event fires.
Usecase
In my pictures collection I have a folder where i want to have "newest first" as details list (because there are no images to see at this level), but its subfolders should be displayed as large thumbnails and grouped by date.
DOpus allows folderformats per folder or its subfolders, but not for "anything below this path", as this script does (or at least i did not find any satisfying way to accomplish this) As stated by Leo this is wrong.
Usage:
Add new Dynamicfolderformat objects to the array at the beginning
DynamicFolderFormat(rootPath, callBeforeChange, folderformat, customApplyFunction, useFolderformatAsFallback)
new DynamicFolderFormat("C:\\", true, "!default", function (beforeFolderChange, tabCommand){ Log("do what ever you want to do here"); return true; }, true)
- rootPath: the folderformat will be applied to subfolders of this path, but not the folder itself
- callBeforeChange: set format before or after folderchangeevent
- folderformat: the format that will be applied but only if customApplyFunction is null or returns false and is not set for fallback
- customApplyFunction: you can define your own event here
return true if successful or false if not
if false and useFolderformatAsFallback is true then the defined folderformat will be applied
otherwise it will look for other DynamicFolderFormats that match this path
When defining a format for a certain folder and one for one of its (indirect) subfolders, make sure to have the "deeper" one further up in the DynamicFolderFormats array because otherwise it will be skipped since the path was already handled by the shorter one.
Resources/Installation
Installation Guide
Version 1.0 - 12.08.2021 - Initial Version Addon.FolderFormat.Dynamic.js.txt (6.3 KB)
// Addon.FolderFormat.Dynamic
// (c) 2021 Felix
// This is a script for Directory Opus.
// See https://www.gpsoft.com.au/DScripts/redirect.asp?page=scripts for development information.
//The actual customization data
var DynamicFolderFormats =
new DynamicFolderFormat("coll://Fotos/Urlaub/", true, "Dategrouped Image Collection"),
new DynamicFolderFormat("C:\\Windows", true, "WindowsSystemFolder", function (beforeFolderChange, tabCommand){ Log("do what ever you want to do here"); return true; }, true),
new DynamicFolderFormat("C:\\", false, "!user", function (afterFolderChangeData, tabCommand){ Log("do what ever you want to do here"); return true; }, true)
//add your dynamicFolderFormats here
// Called by Directory Opus to initialize the script
function OnInit(initData)
initData.name = "Addon.FolderFormat.Dynamic";
initData.version = "1.0 2021.08.12";
initData.copyright = "(c) 2021 Felix";
initData.url = "https://resource.dopus.com/t/dynamic-folderformat-setting-folderformat-for-subfolders-but-not-for-parent/39119";
initData.desc = "Script that sets custom folderformats for folders below chosen parent folders";
initData.group = "Addon";
initData.min_version = "12.0";
// Called before a new folder is read in a tab
// Check for dynamicFolderFormats to be applied before folder change
function OnBeforeFolderChange(beforeFolderChange)
var tabCommand = CreateCommandForTab(beforeFolderChange.tab, beforeFolderChange.qualifiers);
for(var i = 0; i < DynamicFolderFormats.length; i++)
var dynamicFolderFormat = DynamicFolderFormats[i];
if(dynamicFolderFormat.callBeforeChange)
if(StartsWith(beforeFolderChange.path, dynamicFolderFormat.rootPath)) //should be a sufficient check
if(dynamicFolderFormat.customApplyFunction)
var result = dynamicFolderFormat.customApplyFunction(beforeFolderChange);
if(result)
return; //if true is returned, stop searching for other matching formats;
else //otherwise check if folderformat should be used as default, otherwise search for another dynamic folder format
if(dynamicFolderFormat.useFolderformatAsFallback)
tabCommand.RunCommand("Set FORMAT=\"" + dynamicFolderFormat.folderformat + "\"");
return; //job is done
else
continue; //look for another folder format
else
return; //If paths are matching only the first occurence will be applied
//Paths that go "deeper" should be defined first
// Called after a new folder is read in a tab
// Check for dynamicFolderFormats to be applied after folder change
function OnAfterFolderChange(afterFolderChangeData)
var tabCommand = CreateCommandForTab(afterFolderChangeData.tab, afterFolderChangeData.qualifiers);
if(!dynamicFolderFormat.callBeforeChange)
//if(dynamicFolderFormat.path == afterFolderChangeData.path)
if(StartsWith(dynamicFolderFormat.rootPath, afterFolderChangeData.path)) //should be a sufficient check
var result = dynamicFolderFormat.customApplyFunction(afterFolderChangeData, tabCommand);
if(result)
else
else
//Create a command that has the tab set as source with the qualifiers applied that were set at folder change event
function CreateCommandForTab(tab, qualifiers)
var cmd = DOpus.Create.Command();
cmd.SetSourceTab(tab);
if(qualifiers)
cmd.SetQualifiers(qualifiers);
return cmd;
//Datastructure for saving the
function DynamicFolderFormat(rootPath, callBeforeChange, folderformat, customApplyFunction, useFolderformatAsFallback)
this.rootPath = rootPath; //the folderformat will be applied to subfolders of this path, but not the folder itself
this.callBeforeChange = callBeforeChange; //set format before or after folderchangeevent
this.folderformat = folderformat; //the format that will be applied but only if customApplyFunction is null or returns false and is not set for fallback
this.customApplyFunction = customApplyFunction || null; //(after/beforeFolderChangeData, tabCommand): if not null it will be called for custom functionality
//tabCommand is a command with the tab set as source
//returns true if folderformat was applied / custom actions was successfull, else false; if callBeforeChange is true and another dynamic folder format is defined for the same path the second one will be called
//gets passed a beforeFolderChange or obejct depending on callBeforeChange; see
//https://www.gpsoft.com.au/help/opus12/index.html#!Documents/Scripting/BeforeFolderChangeData.htm
//https://www.gpsoft.com.au/help/opus12/index.html#!Documents/Scripting/AfterFolderChangeData.htm
this.useFolderformatAsFallback = useFolderformatAsFallback || true; //if customApplyFunction returns false use the defined folderformat as fallback action
//https://developer.mozilla.org/de/docs/Web/JavaScript/Reference/Global_Objects/String/startsWith
function StartsWith(baseString, searchString, position)
baseString = String(baseString);
searchString = String(searchString);
position = position || 0;
return baseString.indexOf(searchString, position) === position;
function Log(msg, e)
DOpus.output(String(msg), e || false);
