The Complaint
I have an issue with the way delete and recycle work with DO. I have reviewed other posts here saying that files deleted from a network drive cannot be recovered through the recycle bin. This is not correct. I have been doing it for years with explorer and a registry entry. I have switched to DO and this functionality no longer works. This has caused me a number of frustrating moments lately when I needed to get back a file accidentally deleted.
What I Have Been Doing
The only reason Windows does not support network-to-recyclebin (AFIK), is security. If someone deletes a sensitive file, it appears in a recycle bin that others may have access to.
This is not a concern for many Windows users like me who are not sharing access with other people.
A network enabled recycle bin can be added with the registry entry below(only an example)
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\FolderDescriptions\{C5220B9E-2098-4184-8101-1383E28917AC}]
"RelativePath"="X:\\"
"Category"=dword:00000003
"Name"="NetworkDrive2RecyclingBin_C5220"
This works with Explorer but DO does not seem to honor this setting and even Explorer only worked about 2/3 of the time by correctly redirecting files to a network recycle bin.
Suggestion for DO
Here is a simple way to add recycle bin functionality to DO for all drives, even as a backup to RecycleBin.
I have used other programs that deal with network deletions by creating a custom root folder such as \\networkresource\.opus-recycle and any files deleted through that program are actually moved to this regular folder.
This would be a simple option to add to DO with checkbox options to enable/disable, use local drive or use network drive to hold new recycle bin and a button to empty the custom recycle bin, along with a max size so when a new file is deleted the folder size is checked and older files removed if it is above the set maximum size value.
I hope such an addition can be considered for the next update of DO and think it would be useful to most users.
