Version 1.0
A quicker way to access the edit menu for Dopus scripts. Uses the FAYT bar.
- the default activation key is '/'. Then just type the name of your script and press enter. To change the default activation key go to preferences/quick keys. I recommend using [.
- Search is fuzzy.
FAYT_ScriptEditor.opusscriptinstall (4.0 KB)
