editorWrapper : a viewer Using Notepad4 / Notepad++ / EmEditor to preview and edit text files
Notepad4 / Notepad3 / Notepad++ / Everedit is compact yet powerful text editor.
you can download from :
https://github.com/zufuliu/notepad4/releases
https://github.com/rizonesoft/Notepad3/releases
https://www.emeditor.com/
https://www.everedit.net/
When previewing a file, this plugin launches Notepad4 (or N3) to open the current file, and its window will be embedded within the view pane frame.
you can directly edit the file and save it in the view pane.
Notepad4 / Notepad3 / Notepad++ / EmEditor/ EverEdit are all supported.
NOTE: the version of Notepad4 must be newer than v24.09r5472, because its parameters have changed since this version.
PS: You may need DOpus v13.24.1+ to handle more extensions. (In the previous version, the concatenated string of extensions had a limit of 260 characters.)
For viewer plugins, increased the buffer size for the lpszHandleExts field.
Download & Setting
Download the appropriate version based on your language.
Place the dll into "/home\viewers" and restart DOpus.
2026.8.1 :editorWrapper_en.zip (52.4 KB)
2026.8.1 :editorWrapper_cn.zip (52.1 KB)
--2026.7.1 : editorWrapper_en.zip (47.8 KB)
--2026.7.1 : editorWrapper_cn.zip (47.6 KB)
Preferences / Viewer / Plugins, show all plugins,
move editorWrapper up, Or move it to the top.
The setting GUI, you can add extensions and edit the path of .exe.
If the exe path is invalid, the preview action will be delegated to other plugins.
Environment variables, Dopus alias and absolute paths are all supported.
Screenshot
Change Log
v2026.7.1 Now supports Notepad++ v8.9.6.2
v2026.8.1 Now supports EmEditor & EverEdit
tested EmEditor v25.4.4, EverEdit v4.5.0.4500
(Perhaps other editors can also be supportted, but I has not tested)
Add two setting options:
"Maximize window when opening standalone viewer" (启动独立查看器时最大化窗口)
"Focus the editor on preview start" (启动预览时激活编辑器输入焦点 )
Fixed: Focus activation issue in standalone viewer window.
For EmEditor, I made a plugin to handle WM_COPYDATA messages, enabling smooth file switching (reusing old processes to avoid the additional overhead of starting new processes), as EmEditor does not have a publicly available method for handling WM_COPYDATA messages.
Download :
CopyDataReceiver for EmEditor.zip (11.1 KB)
Nice tool and even with german translation! That's great for me.
Some suggestions:
  • For DOpus it should be able to automatically recognize the special extensions ".js.txt" and ".vbs.txt" as JavaScript / VBScript.
  • When viewing a file in viewer fullscreen mode (no title bar or toolbar of the viewer visible) it's not possible to toggle away from fullscreen. I currently have to click the "Close" button to get the context menu of the viewer available.
Many thanks, nice to have options :slight_smile:
Any chance of doing a wrapper for Notepad++
v2026.7.1 Now supports Notepad++ v8.9.6.2 (earlier versions have not been tested)
Awesome, many thanks :slight_smile:
very nb!!!
I wasn't interested until I saw notepad++. :ok_hand:
I haven't tried it yet but does it support theming and macros? i.e can I run plugins from it and split panes? How does that work with file operations outside of the one you've opened?
What are you building this on? Just cross-process window embedding? Does it impact how I can use the standalone notepad at the same time?
Download:
Download :
Is it vibe-coded? It looks promising, though.
Could you please share the source code?
It looks like you should use ResolveAliasPath instead of parsing folderaliases.oxc directly. The method you're using sometimes has issues with some aliases.
Also the plugin silently crashes if you attempt to use it via QuickShow (because you can't have different plugins for each scenario and QuickShow doesn't like embedded windows)
Does this plugin open an executable on top of the DOpus viewer area? What happens if I change focus to another window?
