Elby Virtual Clone Drive Mount-Unmount
I read your forum sometime ago and took a lot of help from you about opus.
I now want to tell u about somethin little i found.
The code u need for making the buttons for Elby Virtual Clone Drive mount and unmount:
Lets say that Virtual Clone Drive is installed at path C:\Programs\CD-R\Virtual Drives\VirtualCloneDrive and the virtual drive has the driveletter P
Mount:
<?xml version="1.0"?> <button display="both" icon_size="large"> <label>Mount</label> <tip>Mount a cd image using Clone Virtual Drive.</tip> <icon1>C:\Programs\CD-R\Virtual Drives\VirtualCloneDrive\VCDMount.exe,0</icon1> <function type="normal"> <instruction> "C:\Programs\CD-R\Virtual Drives\VirtualCloneDrive\VCDMount.exe" /d=0 "{filepath$}"</instruction> </function> </button>
Unmount:
<?xml version="1.0"?> <button display="both" icon_size="large"> <label>Unmount</label> <tip>Unmount a cd image using Clone Virtual Drive.</tip> <icon1>C:\Programs\CD-R\Virtual Drives\VirtualCloneDrive\VCDPrefs.exe,0</icon1> <function type="normal"> <instruction> "C:\Programs\CD-R\Virtual Drives\VirtualCloneDrive\VCDMount.exe" /u</instruction> </function> </button>
Thank u!
