When I perform a 'Find' operation it will often pick up many results from the Recycler. This bloats the results tally and can make the results harder to examine.
How can I do a 'Find' on, say c: and d: but not include the recycle bin(s) in the results?
However, I installed Win7 from a full install DVD to a fresh formatted HD while still using XP on the old HD, then formatted the XP disk and cloned it from the Win7 disk. So I'd be surprised (though not unwilling to believe!) that anything from the old OS remained in place.
But yes, I have $Recycle.bin and Recycler on my c:\system and d:\data partitions on HD0, though only $Recycle.bin on my HD1 second physical HD.
You are implying that that is the reason I am getting these results, I presume? If so, I understand that it's an OS problem and not Dopus but can you suggest a remedy?
I image my HD on shutdown each night so there's no risk in any particular course of action
