I’d like to suggest adding an enable/disable toggle for Evaluator Columns, similar to what’s already available for Script Columns.
With Script Columns, you can disable the script in the Script Management, and the column will be hidden from the “Add Column” right-click menu until re-enabled.
However, Evaluator Columns always appear there, even if you don’t need them temporarily. I have several evaluator columns that I don’t want to delete but also don’t need right now, so a simple disable option would be very helpful.
Nah, I don't really want to move them all into a category... becuse I already have them organized the way I like.
Anyway it's good to know they won't use any resources if they're not being used (which is definitely one of the reasons I want to disable some evaluator columns) — I checked the manual and didn't find this detail mentioned .
