Tbone, I have a little 1" x 4" pocket notes recorder, and each time you record a new "note to self" or whatnot, it stores that note in a separate .wav file. To save the files to your computer, it connects to it via a standard USB cable, and since its internal recording "mechanism" is simply a standard flash drive, it presents itself to my PC exactly the same as if I had plugged in a thumb drive, i.e., as a new drive letter on my PC. The .wav files on the recorder are named sequentially as rec001.wav, rec002.wav, etc., and you then just copy them onto your PC -- using DOpus, of course -- just the same as if you were copying files from one drive to another. (I think you get the gist, eh?)
At any rate, my PC is then left with many, maybe even dozens and dozens and dozens of .wav files (said in my best Carl Sagan voice), and I'd just as soon convert them to .mp3 files just to save disk space. (Although with terabyte drives nowadays it probably doesn't matter anymore to just keep them as .wav files, still the old habits and all that.)
The only audio software I currently have on my PC that can convert from ADPCM .wav files is Audacity, but with that program I have to do them one file at a time, Audacity not having any kind of command-driven interface (as far as I know). So, not good. Takes too much time, and is pretty boring after the first file (or even after the zeroth file).
So I'm assuming that in order to pass a list of multiple files -- dozens and dozens and dozens, even -- to Sox, a DOpus button would have to make use of the {allfile} or {allfilepath} command arguments when I have multiple files selected in a DOpus lister.
So, that's why.
(BTW, my little pocket recorder is the Techerific Rad Recorder. It's great! If ever I go into espionage, I will not have to get a different one, that's for sure.)
Thanks again for the help. Any friend of DOpus is a friend of mine.
