English Language packs (UK English)
When I click on the Directory Opus button on the task bar a message pops up saying the English Language Pack is missing. But when I go into settings, it says it has been installed. I cannot find anything on the internet. I uninstalled the Pack and reinstalled it but to no avail. Any ideas?
Have you tried re-running the installer over the top of the existing install?
This is normally the path it's looking for:
C:\Program Files\GPSoftware\Directory Opus\Language\english.dll
What that that exists and (using the Description column in Opus, or Properties dialog in Opus or File Explorer) has the same version number as dopus.exe in the folder above that.
