In company server directory, I always try to organized/archive folders in chronological order (YYYYMMDD), but also always avoid space in the file names to avoid Hyperlink breaking while sharing the link.
The embedded feature doesn't quite serve all my requirement so I took the liberty to have another try.
Option Explicit
Dim cmd
Set cmd = clickData.func.command
cmd.deselect = false ' Prevent automatic deselection
cmd.ClearFiles 'Bug fixed! Unselect All, to prevent error "Creating subfolder of selected folder"
Dim dlg, ret
Set dlg = DOpus.Dlg
dlg.window = DOpus.Listers(0)
dlg.message = "Enter your folder name"
dlg.title = "Create New Folder | Bryan"
dlg.buttons = "OK|Cancel"
dlg.max = 128 ' enable the text field
' dlg.icon = "warn"
dlg.options(0).label = "Replace Space + Add Date Prefix"
dlg.options(0).state=True
ret = dlg.Show
DOpus.Output "Dialog.Show returned " & ret
DOpus.Output "The string you entered was " & dlg.input
DOpus.Output "The two checkboxes were set to " & dlg.options(0).state
'TODO: Check if target folder-name occupied
dim sInput, sActual
If ret = 1 then
sInput=dlg.input
If dlg.options(0).state then
sActual=Replace(sInput," ", "_")
sActual=YYYYMMDD & "_" & sActual
Else
sActual=sInput
End If
cmd.RunCommand "CreateFolder NAME=""" & sActual & """ READAUTO=yes"
End If
End Function
Function YYMMDD()
Dim t
t=Now
YYMMDD=Right(Year(t),2) & Right("0" & Month(t),2) & Right("0" & Day(t),2)
End Function
Function YYYYMMDD()
Dim t
t=Now
YYYYMMDD=Year(t) & Right("0" & Month(t),2) & Right("0" & Day(t),2)
End Function
By modifying the Functions "YYMMDD" or "YYYYMMDD" with dashs you can customize into the style as you wish.
Dated Folder.dcf (3.2 KB)
