Entry not there / wrong *.dll created? (german translation)
because of a test the 12.33 should be installed again.
it shows this window.
Zwischenablagebild
"additional" is not correct
or future planning?
it is not due to the old 0.44
also present with current 0.57
Zwischenablagebild (1)
i can't find the text in our translator file (tbulic22).
it is also not present in the *.dll!
older/newer entries that have already been made are wrong again
or have not been adopted? (detected as of 0.54)
please send us the current file for checking.
Best to use Slack for this kind of thing.
As far as I can tell, that string is only part of the Opus 12 installer, not the Opus 13 one, and the string comes from the default Inno Setup translations. We're not going to put out a new Opus 12 installer just to tweak that string, but could change it if there are more releases of 12.
slack, can't find anything about it!
this change was made several times in the closed beta
without the message appearing.
correct, is available in the installer
but only since 12.33?
up to 12.32 the intermediate message does not appear
