Error: Registered Print handler
When trying to print PDF's, Dopus errors with the above message.
Any help much appreciated.
Greg
What happens if you do the same in Explorer?
The error message is probably coming from Adobe Reader. If so I'd expect to see the same error in Explorer, which lets you know to look at Adobe Reader (or whatever PDF software you have installed) rather than Opus.
Same problem...and just to clarify what I was trying to do..
I'd select say 6 pdf files, then File>File commands>print....note the file(s) was not opened.
Can you do this?
I'll google round and see what I can find related to Adobe.
Ah, I think this is due to the unusual (but valid) way Adobe Reader adds its Print context menu item, which Opus doesn't currently understand.
