Transcribed:
An error occurred moving '*':
The filename, directory name, or volume label syntax is incorrect. (123)
I'm getting this error every time I try to drag and drop a file from an archive into Directory Opus using Peazip. It works fine in stock explorer, but I haven't figured out a way to "fix" it in Directory Opus, which I prefer using.
I believe that Peazip uses a special method of directly extracting files to a folder rather than sending it to temp first, so maybe that's the issue? Any help or fix would be appreciated!
I'm on the newest versions of both Directory Opus and Peazip on a Windows 10 PC. Thanks ahead of time!
