Hi Guys,
I recently installed some scripts but realised I needed the latest update which I can't currently install. I have switched them off but, as you can see in the image below, I am still getting warnings regarding these scripts.
13/02/2019 23:11 Layout_taskbar_groups.js: Script requires Directory Opus version 12.12.1 or higher
13/02/2019 23:11 Viewer_taskbar_group.js: Script requires Directory Opus version 12.12.1 or higher
14/02/2019 09:59 Layout_taskbar_groups.js: Script requires Directory Opus version 12.12.1 or higher
14/02/2019 09:59 Viewer_taskbar_group.js: Script requires Directory Opus version 12.12.1 or higher
15/02/2019 00:37 Layout_taskbar_groups.js: Script requires Directory Opus version 12.12.1 or higher
15/02/2019 00:37 Viewer_taskbar_group.js: Script requires Directory Opus version 12.12.1 or higher
15/02/2019 10:04 Layout_taskbar_groups.js: Script requires Directory Opus version 12.12.1 or higher
15/02/2019 10:04 Viewer_taskbar_group.js: Script requires Directory Opus version 12.12.1 or higher
Other than removing the scripts until I have updated, is there anything I can do to avoid seeing the warnings?
Regards
Blueroly
