Evaluator: No automatic type conversion for index
I expected Advanced Renamer to use this expression:
{=index + "_" + Chr(64 + index)=}
to create file names with an alphabetical index:
1_A
2_B
3_C
However, index is treated as a string and is not automatically converted to an integer. As a result, 64 + 1 is evaluated as 641 instead of 65, causing Chr() to generate unintended characters:
Fortunately, I can force type conversion with the following modification:
{=index + "_" + Chr(64 + (index as int))=}
Interesting observation: The entire eval expression is case-insensitive, except for int, which must be written in lowercase.
I'm unsure if this qualifies as a bug report or a quick tutorial.
Here's another twist.
{=index + "_" + Chr(64 + abs(index))=} also seems to work, but I can't get the index to increment. {=index=} doesn't increment either.
Yes, this works as well.
{=index=} not incrementing seems to occur after clicking around in the dialog for a while. It has happened to me twice, but I haven't been able to reproduce it consistently.
Closing and reopening the dialog should resolve it.
Thanks.
I saved it as a preset, then closed and reopened the dialog.
That fixed it.
Fixed in the next update.
