Exclude entries in control keys tooltip
Would be nice to have the option to exclude certain items from appearing in the control keys tooltip. Such as the ones you've memorized. Thanks.
We'll add this in the next update. Thanks for the suggestion!
Thanks for adding this feature but most items (not all) aren't saving when unchecking 'Show in tooltip' and then clicking 'Save' or 'Apply'. They still appear in the tooltip and closing prefs window and opening again they will be checked.
Edit: I can see that only user defined/added inline rename keys are in the corresponding config file (/dopusdata/ConfigFiles/regexsel.oxc) and must be the reason they are not saving. Example for Select all, If I 'Share to Clipboard' delete, apply and then Paste back in it'll be added to the config file and from that point the 'Show in tooltip' will be saved.
